Cutting tool
URL: http://www.laser28.org/forum/forum_posts.asp?TID=501
Printed Date: 06 February 2025 at 1:29pm
Topic: Cutting tool
Posted By: Hoodoo
Subject: Cutting tool
Date Posted: 27 October 2011 at 3:51pm
Wich tool is best suited to cut the kevlar hull of the L28? I need to cut a hole in my port cockpit seat to install a Lewmar window.
Posted By: Jon167
Date Posted: 27 October 2011 at 11:22pm
rotozip with spiral bit
Posted By: Mad Max
Date Posted: 03 November 2011 at 6:49pm
I used a sawzall with fine hacksaw blade.  Drill the 4 corners first with a drill diameter  to match the radius of the corners.
Dick #122
Posted By: Hoodoo
Date Posted: 03 November 2011 at 9:33pm
I like that technique. Thanks!
Posted By: Jon167
Date Posted: 03 November 2011 at 11:22pm
the only thing that worries me about a sawzall  is the vibration can have a bad effect with gelcoat chipping and cracking.........just my 2cents
Posted By: Mad Max
Date Posted: 04 November 2011 at 5:04pm
Another option which works great on fiberglass is a 4 1/2 inch angle grinder using a thin fiber disk for cutting steel.  Lots of dust.
Dick #122
