Paint for lower saildrive unit?
URL: http://www.laser28.org/forum/forum_posts.asp?TID=557
Printed Date: 06 February 2025 at 3:28pm
Topic: Paint for lower saildrive unit?
Subject: Paint for lower saildrive unit?
Date Posted: 28 April 2012 at 7:18am
First you sand, then you prime, then you paint - what do you use? When I bought the boat the prior owner provided a can of "Alumaspray antifoulant (#1116 white)" from Pettit but I can't find that so what is the recommended alternative?  Thanks everyone!  :)Bill
Date Posted: 28 April 2012 at 7:26am
Sand to bare aluminum, fill any deficiencies with epoxy filler, any type, then coat with interlux interprotect barrier coat system 4-5 coats. If you plan to sand smooth afterwards add an extra coat or two. No need to put antifouling paint on. This is the best system for the leg that I have seen. Be sure not to paint over the zinc annode.
Date Posted: 30 April 2012 at 6:11am
Thank you!!
