  New Posts New Posts RSS Feed - Bent Turnbuckle
Bent Turnbuckle
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Topic: Bent Turnbuckle
    Posted: 28 April 2013 at 10:29pm
Thanks Bill, you're right.
I had the boat in front of me this afternoon and it was clear as you describe. Thank you, john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2013 at 10:14am
There are only 3 parts to the navtech turnbuckle... the eye end is the part that attaches to the chainplate (it can get bent),  the other parts are the threaded screw (can get bent too) and the part that is swaged onto the shroud (never gets bent)
and note the eye end and turnbuckle screw, this is what you have.
The threaded stud part number listed above is the turnbuckle screw. I have ordered these part numbers before and rec'd the correct parts, unless they have changed part numbers.
Edited by Bill Layton - 28 April 2013 at 10:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2013 at 9:49am
Hi Bill,
Do you have the P/N for the turnbuckle/screw that attaches to the chainplate? In the quote that I got they noted that the EYE-end did not include the turnbuckle.
Thanks, John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2013 at 8:27am
Those are Navtec rigging parts, all are 3/8" thread
Bottom EYE part # D541-1212
Threaded Stud # D320-S12
Anyone who sells Navtec rigging should have it. Goodluck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2013 at 8:01am
During mast raising yesterday, we somehow bent the lower turnbuckle housing of the rear shroud. The piece that attaches to the chain plate. We also bent the joining rod.
Could you tell me how to find a replacement?
Thanks so much, john
This page was generated in 0.297 seconds.
