saildrive membrane template |
Jon167
Joined: 14 April 2011 Location: Webster NY Status: Offline Points: 95 |
Topic: saildrive membrane templatePosted: 02 May 2011 at 1:21pm |
your right great stuff, and it was in my top list........are you located on Cayuga Lake?
Cayuga
Joined: 20 October 2008 Location: United States Status: Offline Points: 45 |
Posted: 02 May 2011 at 12:36pm |
Someone recommended to me 3m Super Weatherstrip Adhesive. I found a tube of this at a local automotive store and it's held up well.
3M™ Super Weatherstrip Adhesive, 08008, 5 oz Tube, Black, 6 per case A strong, flexible, rubbery adhesive that can withstand vibration and extreme temperature variations. It can be used to bond automotive weatherstripping and is a great adhesive for holding paper, cork, or rubber gaskets in place during installation. |
Jon167
Posted: 30 April 2011 at 8:32pm |
I was thinking silicone, I wouldn't use 5200 on anything :)
I will most likely have a look at it more in depth at the end of this season, we are hoping to close the deal on the boat this week. and just need to get the boat in the water with minimal bottom work........it's a long story that maybe we can share at a later date.........thanks again for all your help! |
Posted: 29 April 2011 at 10:39pm |
I have heard that this is adhered with the use of marine silicon, such as is available from West Marine. As I only race my boat under phrf (we have no one-design fleet in Vancouver, I have removed this rubber gasket completely and instead have done some modifications so that I use a fibre glass plate to fill the hole which is totally flush with my hull bottom. I do have one of these gaskets, however, and can make the pattern for you, and I know that they use silicon to glue it on. If one uses something like 3M 5200, then one will never get it off without destroying it, however one might get it off with a heat gun or something if 5200 was used. The whole arrangement with the rubber thing looks really Mickey Mouse to me, so I don't use it.
Jon167
Posted: 29 April 2011 at 9:20pm |
thanks, thats great!
One more question, what kind of adhesive do you use?
Posted: 28 April 2011 at 11:49pm |
Currently in Hong Kong and returning on the 30th. I will plot the gasket with dimensions, etc, and send it to you on my return.
Jon167
Posted: 28 April 2011 at 6:05pm |
Looking for the one on the hull, thanks! can you email it to jonflowerday@gmail.com
Regards, Jon
Posted: 18 April 2011 at 11:13pm |
Which membrane are you referring to. If the rubber one on the bottom of the hull, which really isn't a membrane, but only sort of a cover to add a fairer bottom around the opening in the bottom of the hull where the sail drive protrude, then I certainly have that pattern.
The only other sort of membrane I know if is the sticky gasket that goes between the saildrive and the bottom of the engine. Actually, I think I have one of those, and so probably can make a pattern out of that as well. That part of the unit, however, is so far out of the water that one can make that out of just about anything and tack it on with a bit of silicone or something. It comes no where near the water unless the boat is very far down on it's lines, such as like sinking! Cheers, Frank |
Jon167
Posted: 18 April 2011 at 4:53pm |
anyone have a template for the final membrane at the saildrive?
Thanks Jon
