  New Posts New Posts RSS Feed - Impeller cover
Impeller cover
Winner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Winner Quote  Post ReplyReply Direct Link To This Post Topic: Impeller cover
    Posted: 08 August 2012 at 1:26pm
With a couple of the screws for the impeller cover being a bit finicky to remove unless you have a really small screwdriver, I'm wondering if anyone has replaced these with 319 stainless thumb screws and how that went?
Also, I came across this company that manufacturers aftermarket impeller covers (also with thumb screws).  They have two models.  The first is a regular cover while the second has a cover with a spinning teflon bushing built into the cover itself.  This apparently increases impeller life generally and also delays impeller damage in an overheating situation.
www.speedseal.com
The prices seem a bit high for the product but how much is it worth to you to not have pieces of impeller clogging your water cooling system, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2012 at 1:28pm
yes that is a great system, like you said a bit pricey but it improves the long term picture
This page was generated in 0.250 seconds.
