  New Posts New Posts RSS Feed - Impeller cover
Impeller cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Topic: Impeller cover
    Posted: 08 August 2012 at 1:28pm
yes that is a great system, like you said a bit pricey but it improves the long term picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote Winner Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2012 at 1:26pm
With a couple of the screws for the impeller cover being a bit finicky to remove unless you have a really small screwdriver, I'm wondering if anyone has replaced these with 319 stainless thumb screws and how that went?
Also, I came across this company that manufacturers aftermarket impeller covers (also with thumb screws).  They have two models.  The first is a regular cover while the second has a cover with a spinning teflon bushing built into the cover itself.  This apparently increases impeller life generally and also delays impeller damage in an overheating situation.
www.speedseal.com
The prices seem a bit high for the product but how much is it worth to you to not have pieces of impeller clogging your water cooling system, right?
