replacement for Bukh diesel |
Virginia H.
Joined: 03 March 2012 Location: Hampton, Va Status: Offline Points: 46 |
Topic: replacement for Bukh dieselPosted: 18 August 2012 at 8:33pm |
I am interested in Laser 28 that has the Bukh sail drive but no engine. Anyone been able to us a Yanmar 9hp or other brand diesel with this brand sail drive. Also what does the class rules say about replacement?
Posted: 21 August 2012 at 6:22pm |
Personally I love the Bukh and encourage you to find one. Might not be that hard. I recently pitched up at the Royal Hong Kong Yacht Cllub to be told that five of them were laying in the yard. Unfortunately by the time I enquired Thayer had been hauled to the dump. These engines were designed for use in lifeboats and once were plentiful. Also, some yacht owners gave up on them and switched to outboards owing to corrosion of the sail drive which was not replaceable. There may be some engines laying around. The Bukh is far better than the Yanmar or Volvo. Try harder to find one.
bal149
Joined: 14 August 2010 Location: canada Status: Offline Points: 67 |
Posted: 21 August 2012 at 8:17pm |
The Bukh crankshaft is vertical which permits it to sit above the sail drive. I don't think that the volvo or yanmar are made this way and would have to sit forward (in the galley) or aft.
The Bukh has issues, not the least the lack of a proper oil filter but in the 5 years that I have owned mine it has worked with no complaints. It is a very simple and strong little beast so I would agree that finding one and installing it would be the best solution. See also posts re outboard.
bal149
Posted: 16 October 2012 at 7:30pm |
stumbled on a site that advertises Yamaha SD 330 saildrive. In Canada it is sold by Marineoutfitters.ca. May be of help to you.
Jon167
Joined: 14 April 2011 Location: Webster NY Status: Offline Points: 95 |
Posted: 19 October 2012 at 9:49pm |
all I have to do is look at my key and my Bukh starts....I love it.....
Jon
Pandora Hull#167 Lake Ontario SBYC Past President LYRA |
Posted: 22 October 2012 at 1:30am |
Here is another idea for you if you are unable to fine an engine. If you look at the sail drive, it is really just the bottom end of an outboard motor except that it has no cooling water intake nor exhaust. However an outboard engine power head of similar size joins to its lower unit in just the same way. On the Bukh the sail drive unit attaches to a hollow aluminum intermediate casing the captures the double rubber hull seal between the sail drive and the power head (engine). Four bolts come through the base flange on the sail drive, the double seal, through the casing and into the bottom plate of the power head (engine). So......find say a 4-cycle outboard power head that is perhaps in the 10hp range, fix a 3/8" aluminum plate to the bottom of it with a hole allowing its crankshaft to come through its bottom, and shim it so that the crank shaft aligns with the drive shaft of the sail drive. Any machine shop could make the drive cog for the bottom of the shaft to match that of the Bukh sail drive. Drill and tap the bottom of the new plate to take the 4 nos. 12mm stainless steel bolts that come up through the sail drive and screw the new power head to the old sail drive. The remainder of the challenge is fixing a cooling water pump to the engine but that could be driven from a 3" diameter pulley mounted to the top of the new engine's flywheel.
The system would run on gas, but would be quite economical and smooth running as a 4-cycle, and would save about 50 lbs of weight. I have seen such power heads from Mercury, OMC, and Nissan on Ebay for just a few hundred dollars. It would be a fun project and very simple. Just look at the top of the shaft on the sail drive you have and you will see that it is not difficult to make the part to engage it to any powerhead that will fit into the space. it just needs the conversion plate so that the sail drive bolt circle will match up to it. |
Posted: 22 October 2012 at 12:14pm |
Sorry about the typo's in the above post. I had just come in from two days and nights out racing and was nearly asleep at the keyboard. Hopefully it isn't so bad as to discredit the idea of outboard power head conversion to use over the Bulk sail drive.
Posted: 23 October 2012 at 7:43am |
Be very careful converting an outboard gas motor. Outboards aren’t meant to be inboards. That lack such important safety features as flame arrestors. You’ll need to install a blower.
Posted: 23 October 2012 at 12:47pm |
A flame arrestor would indeed be a good idea, but that is just a simple fine screen over the carb intake. A vent fan would even be a good idea with the Bukh to rid the cabin of the blow-by stink. Not very difficult. Many outboards are used as inboards, or are mounted in a well inside the boat such as the Hotfoots or the Farr 25, Impala 28's, and many other examples. It is correct that having petrol (gas) inboard on the boat in any form requires due care.
