  New Posts New Posts RSS Feed - Exhaust temperature alarm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Winner Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust temperature alarm
    Posted: 23 May 2012 at 8:38pm
I learned the hard way last year that the temperature alarm attached to the post on the aft portion of the engine does not go off until the engine has already overheated (at least on my boat).  In my mind, it is not of much use at all.
Wanting to avoid a repeat of above, I've been reading about exhaust temperature alarms, such as the one found at:  http://www.trickettmarineproducts.co.uk/exhaustalarm.html
I'm wondering if anyone has installed such a device on the exhaust system of the L28 and what their experience has been?
Also, any advice on what temperature the sensor should ideally be set off at?  You want it high enough to not give false alarms but not so high that damage has occurred by the time it is triggered.
Thanks.
Edited by Winner - 25 May 2012 at 12:50am
