Stem fitting |
Topic: Stem fittingPosted: 13 August 2012 at 10:37pm |
The supplied bow shackle was a wichard # 1444
The # 1244 works too
Posted: 13 August 2012 at 9:38pm |
If I'm buying a bow shackle for the forward bow casting position, how much breaking strength should it have? It's a 3/8" diameter hole on my boat.
Posted: 09 August 2012 at 11:03pm |
The normal forestay position is the fwd hole in the bow casting. The aft hole is for the tack shackle. Sounds like someone put it the wrong position.
Posted: 09 August 2012 at 8:50pm |
Semi-related, my boat has been retrofitted with a Harken furler that is currently attached to the aft stem fitting on the bow. I'd like to switch it to the forward stem fitting, thus freeing up the aft one for me to attach the sail tack to during races. Tack of sail closer to deck, better pointing one hopes.
Just checking that this shouldn't be a problem?? |
Posted: 21 November 2011 at 9:47am |
We had 3 different types. Neither of them were complicated... in the sense that if you crawl into the bow with a flashlight and look it'll make sense on how it was done. Sorry I can't be more specific.
Cayuga
Joined: 20 October 2008 Location: United States Status: Offline Points: 45 |
Posted: 21 November 2011 at 7:15am |
Thanks Bill, I'll pull it off and take it to a machine shop. Do you recall the strap/rod inside the bow that the stem is attached to? I'm wondering if this is going to be especially difficult to reattach.
Posted: 20 November 2011 at 11:00pm |
I'd have that re-welded and drilled. I suspect that the forestay must have been too loose for a period of time to do that. If its flared out at the sides then it must be so. I've never seen anything like this before.
Cayuga
Posted: 20 November 2011 at 7:51pm |
I took my mast down last week and noticed that the hole on the stem for the forestay clevis pin has become elongated (see linked pic). I'm not sure how long it's been like this but it looks dangerous. Can anyone advise how I could go about getting this repaired? I was going to pull the stem fitting off but in addition to bolts there is a pin with a split ring on either end. That appears to support some kind of tie rod on the bow inside the boat. Getting it back together looked daunting.
--Andy https://picasaweb.google.com/118341700192635420713/November202011 |
