electrical 101 |
Seawolf
Topic: electrical 101Posted: 09 April 2012 at 11:08pm |
So when I bought my boat last fall the owner
stated that he had trouble with the stop solenoid, or shutting down the boat.
Last summer he installed a new key switch and bought a new stop solenoid. So
this spring I installed the solenoid and started looking at the wire diagram
and the back of the switch plate and traced what wires went where and what they
were for. Some things did not look right and I call upon the group to confirm
my thoughts. 1. The stop solenoid wire (black) was
connected to group of connection that held the green wires, while on the key
switch the black wire located at the nine o'clock position (starboard) goes to a
connection all by itself. The wire diagram I have is a little fuzzy but it
looks like these wires should link up, I am right? 2. The audible alarm sounds off when I put
the key in shut down, (activate the stop solenoid) in both wire configuration
as describe above. However I only get a chirp with all the warning lights when
I turn the key one click to the right (pushed in). Shouldn't I get an audible
alarm instead of the chirp? 3. If the engine is running and you are not able to shut down the engine via the key, what is the backup plan? Thank-you! |
Seawolf
Posted: 10 April 2012 at 2:26pm |
Another follow-up question;
the manual talks about testing the water sensor (sensor that sits between the membranes to alert of any water leak) by short circuiting the sensor on the electrical panel. So I follow the 2 wires from the sensor to where they connect to the mount on the engine. Is this where I am to short circuit? I tried and I have no audible alarm. Suggestions?
