  New Posts New Posts RSS Feed - Bukh Fuel delivery
Bukh Fuel delivery
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon167 Quote  Post ReplyReply Direct Link To This Post Topic: Bukh Fuel delivery
    Posted: 20 June 2011 at 6:55pm
Having trouble with the fuel delivery system on the Bukh, I am fairly certain it is related to the Fuel pump and not the fuel lift pump and when bleeding the fuel are you guys bleeding from the Banjo nut for the return or the compression fitting on the fuel feed?
Any incite would be helpful.........thanks......
