  New Posts New Posts RSS Feed - Companionway slider
Companionway slider
Guests View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Companionway slider
    Posted: 30 March 2004 at 12:14am
The port rail (the one most directly in the sun) for the companionway sliding hatch is severely cracked and needs replacement or serious repair.  Does anyone know where a replacement for this can be found?
It appears to be some sort of black plastic.  I am considering repair with epoxy and fiberglass, but would prefer to just buy a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2004 at 5:48pm
Can't remember if was UHMW or HDPE but its a plastic that we put on the table saw and then routered the edges. These parts were custom made at Laser so it's not something you'll find on the shelf anywhere. A woodshop could make it for you easily. You'll need to find the plastic somewhere though.
Goodluck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2004 at 12:33am
Thank you, Bill.  Not exactly what I had hoped for, but now I know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2004 at 10:56pm
By the way, where can I pick up a suitable piece of UHMW?  What is UHMW?
Foghorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2004 at 11:19pm
UHMW = Ultra High Molecular Weight
HDPE = High Density Poly Ethylene
Hope this helps
Cheers,
Decompression
CAN 214
jez rees View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jez rees Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2011 at 11:59am
Just wondered if anyone had found a source of the companionway slider rails?
I don't think they're PE on FarrOut, so probably UHMW. Anyway, they look kind of expensive to have machined as a one-off with the angled base and internal grooves.
We really need to replace these this winter. Has anyone else had the same problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote frfletch Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2011 at 2:34am
Not difficult. Use UHMPE 3/4" thick by 1" wide. You can buy it by the sheet and rip it. Some of the shops call this MARINE HMPE and it is more UV resistant. We got ours at Industrial Paints and Plastics in BC, but it is not hard to find. Just note the angle of the slot when you set up the table saw. Buy some extra and make a sample to make sure the blade angle is correct to match the flange/lip on the hatch. Next, the table saw makes too much of a gradual finish which will cause the hatch to pry the slides apart and break. This can easily be solved either by finishing the last of the cut with a router or a small cutter on a Dremel, or use the table saw and cut the slot all the way through, then drill and put a screw through the slot to act as a solid stop for the hatch. No problem either way. You can then easy the corners with a planer so that the external edges are not sharp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jez rees Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2011 at 4:04am
Thanks frfletch. I'll give it a go!
Virginia H. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Virginia H. Quote  Post ReplyReply Direct Link To This Post Posted: 02 November 2012 at 10:44pm
How do you keep water from coming under the companionway hatch and the deck?
Post Options Post Options   Thanks (0) Thanks(0)   Quote frfletch Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2012 at 10:58am
When you remove the sliders and take off the companionway hatch, you will find the answer. On the deck under the front edge of the companionway hatch (front when it is in the closed position) there is a weather-seal glued to the deck that makes contact with the underside of the hatch. Since these are not subject to UV, they don't break down and it is likely that yours is in a useable condition. If not, it is not difficult to find a similar material to replace it. Just be sure that when you make your new sliders that you do not use a real thick material that results in your hatch being higher than it is, which would raise it until it was not in contact with the weather seal and allow water in. The correct thickness of the UHMPE from which to cut the slider is 3/4" thick, which sets the height, and 1" wide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Virginia H. Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2013 at 9:53pm
When I removed the companionway hatch the rubber seal is missing. Any ideas on what the shape should look like and where I could buy it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2013 at 10:53pm
It was a self adhesive piece of carpet strip that was glued on the underside of the hatch in the position that when fully closed, the carpet strip is positioned just behind the water trough groove in the deck.... so that any water that gets thru goes into the groove. Should be able to find something at home hardware stores.
Edited by Bill Layton - 14 December 2013 at 10:54pm
