  New Posts New Posts RSS Feed - Traveler issue
Traveler issue
Hoodoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoodoo Quote  Post ReplyReply Direct Link To This Post Topic: Traveler issue
    Posted: 29 October 2013 at 7:52pm
Thanks Bill. I'll try this next spring
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2013 at 8:02pm
Harken states that the torlon bearings must be sprayed with McLube annually. I found mine got a lumpy feeling, like the bearings weren't round. After spraying Mclube it was perfect again for another year. Mine never jammed though. Check your track where the bearings ride against visually. Clean with water hose, wipe down track with a rag, let dry and spray with Mclube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hoodoo Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2013 at 7:52pm
Installed a brand new 27mm Harken traveler with new bolt on track on my boat last spring. Worked perfectly under load until end of season when it started to get stuck.
Any idea of what could be the issue here?
Thanks! JF
