  New Posts New Posts RSS Feed - Hull Repair
Hull Repair
unnamed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote unnamed Quote  Post ReplyReply Direct Link To This Post Topic: Hull Repair
    Posted: 26 February 2012 at 3:50am
I am replacing my transducers and the new ones are larger than the old ones. I used the West System before on a similar project for a different boat, but wanted to see if there was any considerations for dealing with the Kevlar Hull. I also need to repair a small gouge to the bottom. Again I am thinking of using the West System.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2012 at 9:13am
West system is fine. Using a hole saw is what was used at the factory for drilling the thru-hull holes thru kevlar or glass hulls :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote unnamed Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2012 at 8:45pm
Thanks for the confirmation. Now if only Spring would hurry up.
