  New Posts New Posts RSS Feed - water in the hull?
water in the hull?
Seawolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seawolf Quote  Post ReplyReply Direct Link To This Post Topic: water in the hull?
    Posted: 25 March 2012 at 5:22pm
Today I pulled 2 thru hull fittings, one in front of the keel (starboard side) and one aft of the keel (port side). The Kevlar hull in front the keel looked good, solid and dry. Aft was a different story, the previous owner put a dept transducer here, and did not do an adequate job sealing. Although dry, the material between the inside and outside skins was flakey / crumbly and there was a bluish residue. No idea about the bluish residue, but it doesn't look good.
So my plan is to dig out as much as possible, perhaps cutting the hole larger. Then use west epoxy and Kevlar matting to repair the hole. the dept tranducer was located about 4" from the water intake for the engine, I may end of pulling that to be sure the problem did not go that far.
Anyone had similar experience and how did you go about repairing the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seawolf Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2012 at 9:48pm
OK - So I took another look at the hole in the hull and realize this may actually be the "foam core" I am looking at. Again ervery thing looks dry, so maybe I had a premature freakout. But could someone verify this for me? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2012 at 10:25pm
Aft of the keel and port side is a foam cored area.... digging out foam and filling with epoxy putty while its open is prudent,  then re-install thru hull.
This page was generated in 0.262 seconds.
